TOP FEATURES
Premium Boundless Door Design
Adhere to the unity of art and technology
Ultra thin Hinges
Have more space in the kitchen
My Fresh Choice
Hovering Door
Sliding Basket
Mechanical Temperature Control
Highlights
Less is More
Traditional items deserve breakthrough
innovations. This time, we care more
about your feelings.
A brilliant product can satisfy people's dual pursuit of function and spirit, and interpret the taste of life. Thus, we now bring a series of freezer with borderless door design to the market. This design is inspired by a current prevailing lifestyle, which encourages consumer to use item space to a new height.
For this freezer, we get rid of unnecessary decoration, try to convey a "less is more" lifestyle, which is more in line with the decorative style of modern families.
Ultrathin Hinges
The design of the ultra thin hinge allows the freezer to place against the wall,so you will have more space in the kitchen.
My Fresh Choice
Simply turning the temp knob, you can set the temperature of the cabinet as you need, making sure that all kinds of food will be kept in the right condition.
Hovering Door
This design makes it easy to open the door and leave it at any angles between 30 ° and 60 °, which means there's no need to hold it by yourself, allowing for hands-free use as products are loaded or taken out.
Super Freeze
Once the temperature control is switched to freezing mode, the temperature in the freezer can drop to -30°C for its lowest degree, which helps you keep the food fresh, tasty and nutrious as it was just bought.
(W*D*H):
All product descriptions, pricing and dimensions are approximate, product availability, specifications and features are subject to change at any time,and from time to time, and without notice.
