TOP FEATURES
Fast cooling
Cool everywhere
Strong dehumidification
Keep your home comfortable at all times
24 Hour Timer
Easy Installation
Highlights
Take the air conditioner to anywhere you need
Hisense portable
MULTI-FUNCTION
Hisense portable AC can be used as air conditioner, fan and dehumidifier, save more money and living space.
STRONG COOLING
Cool everywhere
Sufficient cooling capacity, rapid cooling, bring you a comfortable summer experience.
AUTO EVAPORATIVE SYSTEM
No drainage, more convenient
No need for drainage often and better for cooling capacity, let you sleep well all night.
EASY MOBILITY
The 4 casters make it very easy to move the air conditioner from room to room.
MULTIPLE USES
Use where you demand, enjoy your life.
LONG DISTANCE AIRFLOW
Three winding-sensing experiences to meet different needs.
SILENT OPERATION
The silent operation creates a quiet and peaceful sleeping environment.
0.5W STANDBY
Ultra-low energy consumption, effective power saving.
24-HOUR TIMER
Make an appointment for turning on or off, simple and convenient operation.
