TOP FEATURES
ANION GENERATOR
Efficient sterilization, make your life more healthy
SELF-CLEAN
Disintegrate dust and dirt through internal frosting
Anti-bacteria Fin
Accurate Temperature Control ±0.5 ℃
I Feel
Easy Installation
Highlights
ANION STERILIZATION
The anions produced by the AC’s anion generator can effectively eliminate bacteria, molds, viruses and pollen, making people energetic, as if being in a rainforest with abundant oxygen.
ANTI-BACTERIA FIN
The fin of air conditioning heat exchanger adopts bacteriostatic fin, which makes the bacteria not easy to breed and the air is more pure.
ONE BUTTON, AUTO CLEAN
Self-clean
The dirt stripper evaporator can quickly disintegrate dust and dirt through internal frosting, and then flushes the evaporator to achieve the purpose of cleaning.
ACCURATE TEMPERATURE CONTROL
Set the temperature you like and it will be kept
With ultra wide frequency control technology, control is more accurate to prevent room temp from fluctuating and keep you comfortable.
I FEEL
The temperature you feel is the temperature you need
The air conditioner can sense the temperature and adjust the temperature and wind speed through the remote control, making you feel more comfortable.
MULTIPLE CONVENIENT DESIGNS
Easy installations
Gas and liquid pipes can be connected when AC hang on the wall with unique easy installation structure, which is convenient and efficiency.
Easy maintenance
New indoor machine structure, no need to move evaporator when you want to check PCB or cross flow fan motor.
Easy Support Bar
Wider Tubing Space
Quick & Easy Replace PCB
Quick & easy Replace Cross Flow Fan Motor
