Multi-split
FREEMATCH
730W x 540H x 260D (mm)
Where to buy
TOP FEATURES
Hisense Freematch Compact Design top feature icon
COMPACT DESIGN
Lighter and more compact units for easy installation
Hisense Freematch Up to 5 top feature icon
UP TO 5
Can be matched with up to 5 different types of indoor units
Hisense Freematch Big Family top feature icon
Big Family
Hisense Freematch New Path Design top feature icon
New Path Design
Highlights
Hisense Freematch Compact Design feature icon Hisense Freematch Compact Design feature icon
COMPACT DESIGN
Lighter and more compact units for easy installation, flexible installation location, larger packing volume and various transportation.
Note: Hisense has the most compact 1 by 2 multi-split outdoor unit model in class.
Hisense Freematch Up to 5 feature icon Hisense Freematch Up to 5 feature icon
FREEMATCH UP TO 5
One Freematch outdoor unit can be matched with up to 5 different types of indoor unit and each indoor unit can be individually controlled.
Note: Refer to the Freematch match table for more information.
Hisense Freematch Big Family feature icon Hisense Freematch Big Family feature icon
BIG FAMILY
We will be having 10 models of R32 Freematch on sale in 2021, which can provide customers with more choices. And this family are all DC so that they can be used in 50Hz or 60Hz countries and regions.
  • Capacity range: 3500W ~ 12500W
  • Match range: 1 by 2 ~ 1 by 5
Hisense Freematch New Path Design feature icon Hisense Freematch New Path Design feature icon
NEW PATH DESIGN
Reverse path design improves efficiency of exchanger greatly. At the rear of the path are super cooling paths, which can improve the cooling capacity and add the length of pipes between indoor and outdoor units. While it is running heating mode, this can prevent base pan from ice block.
ROUND FLOW
360° Round Flow can give optimum efficiency and comfort. Full-flat panel and micro-channel design allow smooth air supply and ensure the best comfort.
FRESH AIR INTAKE
The function of Fresh Air Intake will introduce the outdoor fresh air into the room to improve indoor air quality.
Note: The proportion of fresh air volume cannot exceed 20% of the total design air volume.
Slim Design
The slim duct unit, with a thickness of only 190mm, makes it no longer a challenge to narrow ceiling voids. The external static pressure of up to 50Pa facilitates unit use with flexible ducts of varying lengths.
Flexible Installation
Air suction direction can be altered from rear to bottom suction, giving a choice between free use and connection to optional suction grilles.
Note: The rear suction is 5dB lower than the bottom suction, so it is recommended to use the rear suction.
4D Airflow
The horizontal and vertical air flow swings can provide better room comfort.
Ideal for comfortable air flow in wide rooms:
  • Up to 90° discharge horizontal angle
  • Up to 65° discharge vertical angle
Wi-Fi Easy
WiFi module can be fixed easily in multiple optional positions of the indoor unit with 3M double-sided tape.
The installer can flexibly determine the installation location of the WiFi module according to the strength of the WiFi signal.
Several Airflow Modes
Various air-out combinations of top air-out, bottom air-out and top-bottom make the room air distribution and temperature more comfortable.
MULTI COMFORTABLE AIRFLOW
Precise air supply, optimum air distribution
Because of the left and right independent air deflector design and smart sensing, the precise airflow can follow or avoid people. Soon will feel perfectly comfortable all the time.
Specification
Cooling Capacity:
3.5KW - 12.5KW
Heating Capacity:
3.85KW - 13.5KW
Width:
860 mm
Height:
670 mm
Depth:
310 mm
View More
BACK TO TOP
