Air Purifier
Delicacy Series
345W x 510H x 193D (mm)
Where to buy
TOP FEATURES
Hisense Delicary Series Air Conditioner - Strong Purification Capacity
STRONG PURIFICATION CAPACITY
220m³/h
Hisense Delicary Series Air Conditioner - Modified activated carbon
EFFICIENT FILTERING
With Hepa Efficient Composite Filter
Hisense Delicary Series Air Conditioner - Long-Distance Air Circulation Purification
Long-distance Air Circulation Purification
Hisense Delicary Series Air Conditioner - Low Noise Design
Low Noise Design
Highlights
DESIGNED FOR EXQUISITE LIFE
The exquisite life begins with a pursuit of beauty. The 15-inch notebook-sized purifier, delicate and beautiful, can be flexibly placed in multiple places, cleaning the air and adding a sense of grace.
360° WHOLE-HOUSE AIR CIRCULATION
The optimized air pressure charging system doubles the output of fresh air. Air inlet at the back and outlet at the top achieve 360° whole-house circulating air purification, completely freshing the indoor air quality.
EFFICIENT LAYERED PURIFICATION
Primary filter cloth fibre + high efficiency HEPA filter screen + Columnar modified activated carbon.
The overall improved three-in-one composite filter efficiently filter the ultra fine particles and formaldehyde with the diameter of one-eighth size of PM2.5 and other harmful gases.
Hisense Delicary Series Air Conditioner - Filtered Hair
Hair
Hisense Delicary Series Air Conditioner - Filtered Scraps of Paper
Scraps of paper
Hisense Delicary Series Air Conditioner - Filtered Pollen
Pollen
Hisense Delicary Series Air Conditioner - Filtered Dust
Dust
COLUMN ACTIVATED CARBON WITH HIGH IODINE VALUE
New generation of powerful columnar activated carbon with high iodine value of Hisense and Honeycomb structure is adopted to reduce air resistance. Accordingly, the adsorption efficiency of formaldehyde is greatly improved.
Innate low noise
Sound sleep at night is guaranteed
Multi-wing forward centrifugal fan with unique air duct design, making the machine characterised by low noise. With one-key sleep mode, you can enjoy a sound sleep breathing clean air whole night.
HIGH-EFFICIENCY ENERGY SAVING
During the rapid purification process, the rated power is as low as 42W, which is environmental-friendly and power saving.
BOTH PRACTICAL AND BEAUTIFUL
The pure white frosted appearance, arc design and perfectly continuous curvature make it as smooth as jade. It is also specially designed for babies to prevent bumps and scratch.
* For security reasons, please stay away from the elderly, children, pets, power supply, etc.
Hisense Delicary Series Air Conditioner - Filter Replacement Reminder
Filter screen light reminder No "dirty filter" purification
Hisense Delicary Series Air Conditioner - Simple Panel Control
Sample panel control
Fewer buttons, and easy operation without the need to squat
Operated by standing
Hisense Delicary Series Air Conditioner - Customized Operation and Turn-Off Time
Customized operation and turn-off time
1/4/8 hour timer mode is available
Hisense Delicary Series Air Conditioner - Three Speed Wind Adjustment
Three-speed wind adjustment
Wind speed adjustment
Specification
PM’s CADR Value(m²/h):
220
Formaldehyde’s CADR value(m³/h):
30
Width:
345mm
Height:
510mm
Depth:
193mm
View More
BACK TO TOP
