LCAC
AHU
560W x 1365H x 610D (mm)
Where to buy
TOP FEATURES
Hisense AHU Multi Positioning top feature icon
MULTI POSITIONING
Fit in different type of projects and room structures
Hisense AHU LEAKAGE DEFECTION top feature icon
LEAKAGE DEFECTION
Release the nitrogen from the evaporator coil
Hisense AHU 0.8 In.W.C High ESP top feature icon
0.8 In.W.C High ESP
Hisense AHU 24V Control top feature icon
24V Control
Highlights
Hisense AHU Leakage Detection feature icon Hisense AHU Leakage Detection feature icon
LEAKAGE DETECTION
Before installing the machine, use special tool to press the part as the picture shown below to release the nitrogen from the evaporator coil. If there is no nitrogen released, the unit will be diagnosed with leakage problem.
Hisense AHU Maximum 0.8 in WC feature icon Hisense AHU Maximum 0.8 in WC feature icon
MAXIMUM 0.8 IN. W.C
Maximum 0.8 inches W.C. makes the minimum the temperature difference from different positions and distance of the room, making it possible to connect the longest duct.
Hisense AHU Multi Positioning Installation feature icon Hisense AHU Multi Positioning Installation feature icon
MULTI POSITIONING INSTALLATION
Multi positioning installation is able to fit in different type of projects and room structures.
FLEXIBLE REPLACEMENT SOLUTION
This system use common 24V communication, so the unit is compatible with millions of 24V R410A devices in the market and compatible with the 24V wired controller in the market.
* Contact with distributor for more details.
Compact Design and More Protective
Side discharge compact design provides better protection in different tough weather conditions.
Flexible Connect Pipe
Maximum 98 ft height difference and maximum 246 ft length.
Wide Temperature Range
-13°F (-25°C) Lowest Ambient Temperature for Heating: 5°F (-15°C) Lowest Ambient Temperature for cooling.
Wide Operation Range Heating -13~75°F
Wide Operation Range Cooling 5~122°F
Specification
Cooling Capacity:
24000Btu/h - 36000Btu/h
Heating Capacity:
400 (23524000Btu/h - 36000Btu/h
Width:
560mm
Height:
1365mm
Depth:
610mm
View More
BACK TO TOP
