TOP FEATURES
24H TIMER
MULTI-PURPOSE
SLEEP MODE
AIR DIRECTION 4-WAY Fan Speeds - Cool/Fan 3/3
WIFI
EXHAUST SWITCH
WASHABLE FILTER
FILTER MONITOR
Highlights
MULTI-PURPOSE
You can set any hours in a day to turn on or off the unit.
24H TIMER
SLEEP MODE
In order to give you the best sleep, the sleep function automatically adjusts the room temperature, fan speed and will shut off the light of the unit.
AIR DIRECTION 4-WAY
The horizontal and vertical swing improve distribution of cooling, make you feel more comfortable.
3 cooling and fan speeds allow you to customize your cooling.
Wi-Fi CONTROL
Conveniently control your air conditioner anywhere with just your mobile phone and a Wi-Fi connection.
EXHAUST SWITCH
Pull out the exhaust air vent control to Open the exhaust air vent and draw stale or smoky air from the room.
Push in the exhaust air vent control to close the exhaust air vent for maximum continuous cooling.
NOTE : The exhaust air vent control will function only when the Fan Speed control is operating.
WASHABLE FILTER
With a quick rinse, you‘ll achieve maximum performance while saving time and money. No worried about changing the filters frequently.
FILTER MONITOR
(360h indictor will remain on 180h )
When the PAC ran on for more than 360 h , the pilot lamp (filter) on the control panel will flash to remind to wash filter.
Use the filter button on the remote controller can turn off lamp , or it will turn off itself after 180h.
